Arlo Go + New App + Enabling Geofencing: HOW?
  • 22 Replies
  • 2328 Views
  • 3 Likes
  • 6 In Conversation
er-minio
After many years, my app has been updated to the new system/design.
My setup is a single Arlo Go (1st gen) that is armed when I am away from "home" location.
Switching to the new version of the app messed up all the settings.
The way you have to select the location is now only by address (putting a pin on a map would be WAY more accurate in a lot of locations, but I digress).
Issue I have is that, now, my camera is triggered every time.
I tried both modes:
- Custom Mode selecting the camera from the dropdown and putting it on "geofencing"
- Arm Away Mode, but there is no devices associated and no way to add any (see screenshot)
I appreciate that a major app version change like this would disrupt user habits a bit, and that is ok, but I am really struggling to make sense of the current UI.
The geofencing area is correctly set. The device is listed (under the settings) within the location. The app has location services permissions on iOS set to "Always".
I want the camera to be disabled when I am inside the geofencing area.
System is set to "Arm Away" currently, to no avail.
HOW.
Thanks.
22 REPLIES 22
BrookeN
Geofencing is not compatible with the Arlo Go at this time. If you wanted to use Geofencing with the Arlo Go it would need to be Arlo Go 2.
er-minio
Really?
But Geofencing is managed on the device (phone) side Vs a fixed location triggering a change of status in the system. Camera model should have absolutely nothing to do with it.
BrookeN
Unfortunately, the Arlo GO does not support Geofencing. It can be used with custom modes but not Geofencing.
er-minio
It would have been useful if this information was relayed to the user when prompting for the app update.
I would have kept the old app/account version as everything worked correctly.
Not for long, since Arlo is rapidly phasing out the old interface.
er-minio
Update: I was able to make this work. I have no idea why it has been said that the first gen Arlo Go doesn't work with Geofencing.
I did set up routines that arm/disarm the system as I approach the location and it now seems to work correctly.
The camera is armed/disarmed automatically as I approach or leave the geofencing area, I can see all the activity in the feed. So far it seems to be good.
Took me a while to understand how to set it all up because the app is, frankly, poorly designed. At least around the routines, and it's not very clear how to set them up at first, you get a lot of (inexplicable) empty states for cards/lists and items that seem to be "tappable" (clickable) but unresponsive. Margin for improvement over the routines/modes section.
I suspect you did this using the standard modes and Automations. It's the custom modes and Automations that don't work for the Go, Q, etc.
er-minio
Ah yes. It is using standard modes (the top three choices).
Again: fairly complex to understand how to set it up, so I decided to completely ignore the custom modes options.
The camera is still going strong after several years in operation and very happy with the hardware, but as soon as the hardware fails I'll move away from the Arlo ecosystem to be fair. But I suspect it won't be anytime soon. 🙂
Well, you need to use custom modes with the original Go.  So maybe ignore the three standard modes instead.
er-minio
It is working with the standard modes and the automations I set up.
Do custom modes work or not with the original Go?
I am confused now.
But, again: the set-up is working at the moment using the standard modes and making them switch through the geofence (arrive/leave action).
Sorry for posting contradictory info.  Some cameras aren't supported at all in custom modes (and don't appear in the custom modes camera list).  Others have limitations in the standard mode.  I think this is a bit of a moving target though.
If the system is working for you now, then leave well enough alone.
er-minio
No problem Stephen! Thanks for the help.
Yes, I'll test it a bit more, but the setup seems stable for now.
I can see what you mean: with multiple cameras it could be a bit of an issue (what the ArloGo is compatible with and what not) but in my single camera set-up we should be ok.
Fingers crossed 🙂
JoakimWe
I wish you'd take the time to do a step by step for setting it up, i have struggled for 2 weeks now with the extremely confusing app.
(used to work just fine, update - total mess)
JoakimWe
Start your own discussion thread, and let us know what cameras you have running, how you want it to work, and details on how it is (not) working now.
Ylewaz
I can't set the amount of time for motion video recording ever since the app change.
Other settings I'm still trying to get use to.
Are you setting this in the "Default mode settings" section in the camera settings?
er-minio
It is.
I think there must have been some update, things stopped working.
Default modes with triggers to enable/disable don't work anymore.
Custom modes: the Arlo Go is indicated as camera, but it doesn't recognise the Geofencing somehow. It just switched modes once.
Again, understanding how to set up the app is very hard. Very, very confusing.
As of yesterday, the app is listed as "disconnected". The SIM is ok, but I'll wait as I had two or three random camera disconnections over the last few years, and this is most probably a mobile network issue, not Arlo.
er-minio
I went back to Custom mode.
This is what I see.
From the little dropdown (magenta circle) I manually switched the camera to "Armed".
I'll see if it disarms it when I reach the location later today.
It didn't do anything yesterday.
The little note: "This device no longer supports adding or editing Modes and Schedules. Once deleted, they cannot be added." wasn't visible from the mobile app, only from the web.
Screenshot 2026-06-01 at 16.25.03.pngScreenshot 2026-06-01 at 16.25.10.pngScreenshot 2026-06-01 at 16.25.20.png
BrookeN
@er-minio were you able to get this set up and working how you are wanting it?
er-minio
Not at all.
The Go is only recognised by custom modes in the app.
Geofencing in custom mode doesn’t work.
i have to manually open the app and arm disarm the camera from the custom modes dropdown that is also kinda fiddly compared to the big call to actions/button of normal mode or older versions of the app.
BrookeN
The Arlo Go does not work with Geofencing, you would have to get a Go 2 if you are wanting to use Geofencing.
er-minio
I get it. But, I reiterate:
1. It was working perfectly before the app updated to the new system (feed view).
2. When I was prompted to do the update (I knew I was on the older version of the app because of legacy hardware) there was no mention over "you will lose functionality" or anything like that, otherwise I would have not updated or - at least - waited until I could find an alternative solution.
Since I can arm/disarm the camera, within custom mode, from my phone... I really do not understand how Arlo cannot make geofence work (when it works) for older cameras as well. But I can appreciate there could be technical/backend limitations.
I am sorry to say, but given the "quality" of the software from Arlo these days, I really doubt I'm going to invest some more money into the Arlo ecosystem to get a Go 2. At this stage, I'd probably move to another brand completely.
  • 22 Replies
  • 2329 Views
  • 3 Likes
  • 6 In Conversation
