Arlo Go Case not Closing
  • 2 Replies
  • 2600 Views
jmercmon
I have a brand new Arlo Go and the Case back doe not close fully with a battery. I have tripple checked its inserted correlty and you can squeeze the case clased but whne you release pressure it gaps back open. I ahve solved this for now by holding close and puting a few pices of scotch tape and it says closed.
Is this normal, is there some adjsutment I can try to fix the issue?
brh
@jmercmon
This is not normal and it could allow moisture and dirt to get inside. You might want to exchange it.
Brian
We've seen that. It's not necessarily a problem but it's disconcerting. A swap would be useful or, if not possible, use a little O-ring grease on the seal to ensure a proper seal.
  • 2 Replies
  • 2601 Views
