Arlo Camera Misty
  • 1 Reply
  • 2113 Views
Flumpy999
My arlo camera has gone misty , I thought these were waterproof. Any ideas of is it a new camera as this one is 16 months old.
It may be the seal is not in place right...
Since they are out of warranty, you can possbily dry the cam out by  doing the methods that have worked with other damp electronic... place it open in a container of rice comes to mind.... after afew days the rice should absorb the moisture.
Then check the seal at the battery door  ( I have a couple out in rain for over two yrs now without issues, so somthing isn't right )
  • 1 Reply
  • 2113 Views
