Argo Go lights visible at night?
  • 1 Reply
  • 1619 Views
eberwhitewoods
I have an Arlo Go installed (where I can't access it now) and I didn't check this before I installed it. I don't want any lights emitting from it at night - I was under the impression IR light was not visible to humans, so it would be invisible at night.
On the app, I turned off all LED indicators. I then read online that if night vision is turned on, the camera will give off a red glow. Again, I can't test this becuase I don't have access to my camera, just through the app.
My question: with all LED's turned off and night vision turned off, will the camera be compeltely invisible at night, even when motion activated to take a video?
How bright is glow from night vision if it turned on? Does it glow red all the time, or just when motion activated?
The IR illuminatos glow a dull red only activated. The catch is that if you don't have external lighting, your video will be useless. You can turn them off by turning off Night Vision in the camera settings.
  • 1 Reply
  • 1620 Views
