App takes too long to load for more than 10 cameras and mode section impossible to scroll down
  • 1 Reply
  • 1445 Views
bmattocks1
I have a few complaints with the app that I am not sure if they have been addressed yet or not.
1. If you have more than 10 cameras on the app it seems to take a long time to load.
2. When going to mode section on the app if you have alot of cameras (I have 25) when you scroll down it automatically scrolls back to the top without touching anything making it nearly impossible to arm or disarm them without having to go on a laptop or computer.
3. For arlo go users there needs to be a way to create a group to put all your cameras in so that way you dont have to edit the schedules individually, arm them individually and disarm them individually.
JessicaP
Hi bmattocks1,
What phone device are you using when using the Arlo app? Make sure you're using the latest Arlo app version. If you are, try to reinstall the app and reboot your phone device to see if that helps.
  • 1 Reply
  • 1446 Views
