ARLO GO VS RACCOON
  • 1 Reply
  • 2229 Views
Sarrahbrianne
A raccoon successfully unscrewed my arlo go from the tree and pulled the skin off and ate it! I ciuldnt find the securing white piece that screws up into the cam to tighten it. Does anyone know where to purchase more? Thanks!
Kewl!
Any hardware store should have a selection of metal and nylon 1/4"-20 nuts. Make sure to get a small one if using the power plug.
  • 1 Reply
  • 2230 Views
