video picture small
the live feed video picture is size of postage stamp how do I make it bigger?
Last year when I used the camera I was able to fill my cell phone screen.
When you start livestreaming you should see two arrows in the upper right of the screen. Press that and the livestream should expand to full screen.
Hi and thank you for your suggestion. It does not work though, the live stream picture is a small square to the left of my samsung screen. There are no arrows to press. Must I upgrade to get a larger picture? I'm able to expand the inside of the square but not the border of it. I'm trying to keep an eye on a pregnant ewe in her stall, she is due in two weeks.
If you first touch the video image, do you then see various controls?
I had to click on device and after I did that I was given the option of the arrows. So problem solved and thank you!
