Water Ingress into case
  • 2 Replies
  • 523 Views
Andrewjl
Just wondered if anyone had the same problem..  we had horizontal rain last night and all cameras pro4 , ultra and go2 cameras got water inside the case.
Any suggestions for stopping this .  I don't want to go down the silicon sealant route for obvious reasons for servicing.
It's not SEALANT that recommended, it's silicone GREASE on the o-ring. Remove the camera from the case and carefully remove the o-ring. Apply a light coating of the grease to that o-ring and reinstall, ensuring it's properly seated in the groove on the camera. Insert the camera into the case, ensuring you hear a click as it locks into place.
Andrewjl
Good idea thanks.
  • 2 Replies
  • 524 Views
