Using ARLO GO 2 without connectivity
So, I just purchased an Arlo Go 2 with the intent to set it up, then use it in an area with no connectivity as there is no wifi and there is no cell reception where it is needed. It was my understanding this camera has this capability. I have inserted a microSD, but either the camera does not recognize it or the microSD (which is brand new) is defective because the app does not allow me to turn on local storage. I am perfectly aware I will not receive notifications, etc. like I do for my connected ARLO devices, but I just want to record and view footage from the microSD. The ARLO support agent tells me I cannot use this camera without some form of connectivity, as it will not recognize motion if it is not "connected". Is this true? That is not what is suggested online, but I've never used an ARLO Go. Any recommendations are appreciated. Please remember, the area I want to use the device does not have cell reception or wifi. I am only interested in recording footage to the microSD to review after collecting the card from the camera. Thank you in advance for your comments and suggestions. 🙂
It needs connectivity.
If you have no connectivity but would like to save locally, it's best to get a photo trap.
Thank you. I just wanted to double-check, as I had found some conflicting information. I do have some hunting cameras already, but was hoping to add to that with ARLO. Your help is much appreciated!
