I am trying to add an Arlo Go 2 to my new account. I can successfully go through the device registration process:
- press sync button, blue light blinks
- Device chimes to indicate it successfully connected to my wifi network, after point the device at the QR code
- I can ping the camera's ip on my home network
After a long wait time, the portal eventually claims my device has been added. However, my dashboard says I have no devices. I have gone through this process multiple times using the web portal from a pc and using the app on my mobile device.
A couple of things to note:
- this device is pre-owned. Could this device already be associated to another Arlo account??
- I don't yet have a sim card installed. I am trying to add over wifi.
Any suggestions?
Figured it out.
Instead of simply pressing the sync button like the instructions indicated, I needed to press and hold the sync button for 15 seconds to reset it first. Once that step was performed I was able to successfully add the device to my dashboard.
Figured it out.
