How to best review videos on SD card?
Because my camera runs off cellular data and is almost constantly recording it saves only to SD card. It looked like in some of the chats videos saved to SD card could now be reviewed remotely? I did not see how tho and will likely chew up a lot of data?
Does anyone know how to quickly review all videos on SD card? When I put card into reader/my computer there are hundreds and hundreds of small clips. Is there a program where it will automatically go from one to the next and I can watch them all on fast forward? I am looking for certain events and if I see them would then like to know date and time they occurred
Unfortunately, locally recorded videos on the Go 2 cannot be viewed via the app. Only the videos stored on a hub can be directly viewed and the Go 2 doesn't support that connection.
