How long are the video clips that are recorded on the cloud.
How long are the video clips that are recorded on the cloud. I want to install in a grooming van and tape the grooms. Do they record in 1 minute increments or continuous until there’s no motion? Also is there a cord that I can plug in that will continuously charge the battery?
I don't think the Arlo cameras are the best option for this application.
I don't have a recommendation though - perhaps others here will chime in.
You can set the duration, or use "until motion stops". The max fixed duration is 2 minutes, the "until motion stops" can last up to 5.
Yes.
