Go 2 vs. Pro 2 size
  • 2 Replies
  • 2532 Views
KeithW13
I am looking to purchase a skin for the Go 2 camera and it is hard to find a camouflaged one advertised as for the Go 2 - is the Go 2 the exact same size as the Pro 2 (they appear similar)??
Streak2
Master Master
The Go2 is considerably bigger and totally different in shape to the PRO2.
As @Streak2 says, the cameras might look similar in a photo, but they actually are quite different in shape.
Pro 3/Pro 4/Pro 5/Ultra use the same housing.  Pro and Pro 2 camera skins are compatible with each other (but won't fit other models)
But the Go 2 has a unique shape, and AFAIK no one makes a camo housing or skin for it.  Some folks use enclosures as camo (for instance, something that looks like a bird house).  You do need to make sure the motion sensor and IR Leds are exposed though.
  • 2 Replies
  • 2533 Views
