Go 2 Activation with Verizon finally worked after challenges -- APN required
Had trouble activating the Go2 on LTE
Spent 2 hours with Verizon support, ending with Tier2 support.
Finally worked!
They got the IMEI and ICCID from me. They "put it back in the system"
Meanwhile I added vzwinternet to the APN when Arlo setup fails
Power cycled the device (leave off for 2 mins)
questions:
1). do we need to manually add the APN or should this come default set by Verizon
2). any other tips for future activations to make it more seamless
JayKay2022,
I believe these settings should be applied by default. If you experience issues in the future, please let us know.
