Cannot get camera to connect to app
  • 1 Reply
  • 1547 Views
mckinneybuilder
I have tried to connect my arlo go 2 camera and once the app has me name the camera, it gives me an error code.
I have tried to connect it over the web, have done a factory reset on the camera as well as deleting the mobile app and re-downloading it.
Anything else I am missing?
Streak2
Master Master
What error code is it giving you?
If connecting via wifi then after selecting the SSID and entering the correct wifi password you should be presented with a QR code to scan. After scanning the code with the camera it should then onboard.
  • 1 Reply
  • 1548 Views
