Arlo Go 2 and verizon
Hello,
I use Arlo Go 2 to watch over my farm. Where I have decent coverage it works very well, but I have dead zones that they don't work well at all. I have been looking for a way to boost the cell reception but I don't have electricity readily available in these dead zones. Anyone have any suggestions?
Not sure if this is the correct place to post but thought I would start here.
You'll need power to use a cell signal booster. You could look into deploying an outdoor wifi network as an alternative, though that will also require power.
How far are the dead zones from power?
Power over Ethernet is one possibility (for an outdoor wifi solution, not sure if any cell signal boosters use that). But the spec'd distance for that is 328 feet (100 meters), so it might not be suitable.
