Arlo Go 2 - I want a 24/7 video stream to PC
Hi, I bought one Arlo go 2 to use for the operators in an process industry to use as an mobile cctv camera. Sometimes we need to supervise certain areas for 1-2 days. I understand that isnt an profesional cctv camera. We have alot of them as well. But this camera was wireless, built in battery, LED-light and could be mounted on tripod without any problems. So the camera i cannot complain about. I bought this just to try and if we didnt get this to work I will go for more professional camera and "build" some case with routers and battery
But the idea was to use the webinterface(https://my.arlo.com/) but this will very often "go down" and we get an alarm that says something like "unexpected error, try again". Wifi is maximum connection. Use the app isnt an solution, it should be on a PC. I understand the battery could be an issue but that is someting I can solve.
What I want is 24/7 video stream to PC and something that will automatic reconnect if we get an network error or similair.
@KristofferL81 wrote:
What I want is 24/7 video stream to PC .
None of the current models will do that - they all time out after about 30 minutes.
There is a continuous video recording subscription, but that requires the camera to be connected to AC power. Plus it isn't available for the Go 2.
