new essential spotlight wont charge
Recently purchased VMC2330 2 of the 3 cameras worked fine. The 3rd one blinked blue a few times before stopping any blinking. No lights when being plugged in with supplied charger or charger from my other cameras. Also tried multiple blocks all at least 3.0. left on charger for 12 plus hours no response. Tired factory reset and no lights. Charging contacts look brand new.
Maybe try a reset next - holding down the sync button for > 15 seconds (until it flashes amber).
If that doesn't work, I'd exchange it with the seller if possible (that is faster and easier than a warranty return).
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
