cam speaker can only be faintly heard
I can't get the cam speaker volume up loud enough to use in the talk back function. The app volume level says it's 100%. It can only be faintly heard... too low to even be counted as a feature. Was in a "chat" session with tec support today for over an hour. They were not helpful and gave up... cut me off. Can any body help. I need the talk back function. I can hear them a little, but they can barely hear me at all. Thanks for any help.
I have a Samsung galaxy phone S20 FE
Does it work any better using an iPhone?
I don't use an iphone. My phone is Samsung
I recall reading a number of previous posts over the years related to similar behaviour using the arlo app on some android devices. No solutions I recall.
https://community.arlo.com/t5/Arlo-Pro-2/Arlo-Pro2-push-feature-low-volume-and-android-application/t...
If you have a subscription you can contact arlo support via the arlo app and raise a fault case.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
