Video stored only in cloud not local storage
Hello,
i have essential xl with spotlight cameras with a smart hub base vmb5000 with sd storage.
Now i see my videos are only stored at the cloud an not on the local sd storage how can i activate this.
The sd storage is formatted and the the system says that the sd storage is okay.
gr
Michel
Are the cameras connected to your smarthub? Or are they connected to your home wifi?
Hi Guru,
They are connected to my home wifi.
Local storage only works for cameras that are connected to the hub.
If these are Gen 2 cameras, they cannot be connected to a hub yet - Arlo says they will add that feature, but no details on when.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
