Video Settings
The video square is stuck in the right bottom corner pinch it too small can't get it to move,help !
Do you mean an activity zone? You can delete it by swiping left on the zone entry at the bottom. Or do you mean a zoomed in view in Video Settings? I don't have an Essential set up so can't test but do those cameras support multiple Field of View settings that you may be able to change to see if that helps?
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
