GREAT 4 CAMERA SYSTEM!
3 CAMERAS STILL GOING STRONG AFTER 8 MONTHS OF USE.
ONE CAMERA WILL NOT CHARGE.
I WANT TO EXCHANGE/REPLACE THIS ONE CAMERA.
I CAN NOT GET AN RMA.
I CAN NOT TALK TO ANY LIVE PERSON!
Do you have a subscription?
If you do, check the support area of the app. There should be a phone icon in there - if you press it, you should get phone support.
anyone know how to contact returns?
YES, I DO HAVE A SUBSCRIPTION AND NOWHERE IS FOUND A "PHONE" ICON.
Try
- opening the app
- select Settings
- scroll down to "Support" and select it.
- Choose a camera that is covered by the subscription
- Scroll down to the "contact" section.
You should see Chat, Community, and Phone listed there.
I FEEL LIKE I AM WHIPPING A DEAD HORSE!
All I can say is that I see a phone option there for my cameras. Are you seeing only chat and community? Or not seeing the contact area at all?
Note this HAS to be done in the app - not my.arlo.com.
GREAT TIP, THANK YOU. I CALLED. THE RECORDED VOICE KEPT ASKING ME FOR THE ORDER NUMBER. i COULD NOT AND IT HUNG UP ON ME. NO OTHER NUMBERS! CALLED AGAIN AND AGAIN.
THE RECORDING SAYS, "PLEASE ENTER YOUR ORDER NUMBER" and then hangs up.
I WOULD LIKE TO BUY ANOTHER SOLAR CHARGER AND THE DOORBELL DEVICE. BUT, I KNOW I WILL NEVER GET HELP.
C52,
I don't see any cases attached to your account. To contact support, log in to your Arlo account via the mobile app and navigate to Settings > Support. From there you can select the device for which you want support and a list of options will be given (including phone support).
OCTOBER 26, 2022 STILL NO HELP. ONLY LOOP REPLIES.
AFTER HOURS AND HOURS OF ATTEMPTS, I HAVE 2 OUT OF 8 THAT WORK!
AFTER 2 MORE MONTHS OF FAILURES, I AM THROWING ALL 8 CAMERAS AWAY.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
