Hello,
I recently purchased a VMC2032 for outside and I have noticed that after adding it to the app and on the Arlo Portal, it is identified as VMC2030. Is this normal?
Please advise.
Thank you!
I'm not certain of the reason but the VMC2032 is the XL version of the VMC2030. It's visibly larger and should be obvious. The only difference is the size of the battery and, hence, the case so the hardware is the same otherwise.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
