VMC2030 volume is too low
I use my camera to monitor my dog when he is left home alone. The audio is very low even in a small room and he is only 4m away. Can I increase the volume?
Is the volume low in recordings, or is it only low when livestreaming?
Both unfortunately
@Jonesoz wrote:
Both unfortunately
There is a speaker volume setting, but not a microphone.
Are you using a Samsung phone (many people with this complaint are)?
One thing you might try is using a bluetooth headset, and see if that has better volume (several others have reported success with that workaround).
Thanks, Yes, I use a Samsung phone or my laptop and it maybe slightly better but not really what I hoped for.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
