VMC2030 - two wifi connections?
I just bout this, but I will return if I can't connect to two different wifi. My dirveway is 1300ft long and my neighbor will let me connect to their wifi so I can have a camera at the top of my dirveway. However I also want to use my home wifi for the other camera's. Can I do this with this model number. By the way I HATE not having a customer support phone to talk to an actual person. Right from the beginning I'm not impressed with the lack of customer support.
When you onboard each camera, you tell it the wifi network to which you want it to connect (network name and password). The phone running the app needs to be on the same network that you want that camera to use. Different cameras can be onboarded to different networks.
The neighbor will of course need to trust you with their wifi credentials. The neighbor won't have access to the camera (or any stored videos), unless you share the camera using the "friend" account feature.
FORGET THIS, NO CUSTOMER SERVICE....I returned Arlo and picked up a Ring....already happy with my Ring!
tjones112,
Did you experience an issue during setup? What you're trying to do is possible, you just need to connect your mobile device to the desired network before you start onboarding each camera, as StephenB mentions above.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
