VMC 2030 camera not connecting
  • 2 Replies
  • 1501 Views
pri123
I have 3 Arlo wireless cameras (VMC 2030).  Two of them work but the 3rd one does not.  I have tried everything and it just will not connect to Wi-fi...and is currently unusable.  I need some tech support and advice.
Dannybear
You could try removing one of the working cameras and then install the problem camera. If it works then try installing the previous working  camera again. If it fails to connect then it suggests you need a subscription for the third camera.
You should still be able to set the camera up but not be able to use it as expected.  There's been a number of complaints about 3rd cameras not connecting but I don't know of a real resolution unless a reset of the problem camera helps:
https://kb.arlo.com/000062438/How-do-I-factory-reset-and-re-sync-my-Arlo-camera
