VMB3500 not found
Define "reset" - holding the reset button until the LEDs flash amber? Many folks refer to rebooting/power cycling as a reset, which it's not.
Moving or getting a new router doesn't remove the base from your account. Since it uses Ethernet to access the servers, all that's needed is to unplug from the old location and plug it in at the new one. There are potential issues that can pop up, however, starting with cables not being properly plugged in to the ISP blocking access.
Since the base LEDs are green, it's already configured. You should simply log into the app (or web client) and see your cameras. If not, tell us all about what you see, including any error messages. All details are important.
Juicy20,
Follow the instructions here to make sure a factory reset has been completed: https://kb.arlo.com/1057976/How-can-I-reset-my-Arlo-SmartHub-or-Base-Station
Once the reset is completed, try onboarding the base station as if it were new. Be sure you're mobile device is connected to the same network that you're trying to add the base station to.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
