- English
- Cameras
- Trouble shooting essential wireless camera set up
I am trying to set up an essential wireless camera. I am able to get up to the point where it creates a chime. However, the device is never discovered. I have been successful with other devices past this point, But not with this one. Do you have any advice?
Thank You
Arlo Essential Spotlight Camera
Try a PC using my.arlo.com instead of the app. If your router lets you disable 5 Ghz wifi, then do that while onboarding.
Also, make sure that your home network
- uses WPA2 (AES) security
- has no punctuation in the network name or password
Other Arlo devices? If so, are they connecting to your home wifi? Or are they base stations connecting via ethernet, or cameras connecting to a base?
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
