I am confused about the check marks on the Filter screen.
Under the Arlo Smart Notifications section,
does a check mark indicate that you will receive a notification for that item?
Or does that mean you will NOT receive a notification?
For example, if there is a check mark after People but not after Animals, does that mean you will get a notification if a person is detected but not if it's an animal?
Or are you filtering OUT a notification?
Is it the same for Motion?
In all cases, removing the check mark filters out the notification. Motion is a catch-all for unclassified events.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
