This is a problem with the website, not the mobile app. I do not know if it is the same for the mobile app We really need a way to provide feedback for the website that is independent of a model.
That is not the problem I am asking about. The problem is that when I search the community, there are results shown that have other stuff overlapping over it so the results cannot be seen. Does that happen to you? Is there a way to get the extra stuff out of the way?
@SamHobbs wrote:
@StephenB wrote:
- If the focus is inside the search box, I do see a section that is half covered (similar to yours)
Yes, the feature I am talking about is only a convenience but I assume the form is not working as designed.
Yeah, I get your point.
I'm tagging the mods ( @JamesC and @ShayneS ) to call their attention to this.
This is what I see (using Edge, though I see the same thing with Chrome):
Is there something unusual on how you set Windows or Edge display settings? Have you tried a different browser?
You have nothing in the search box. What happens when you put something in the search box? Does the contents under the box go away or does it remain there and overlap the results shown below the search box?
Note that in the image I posted there is a White area under the search box, much like what many search tools show. Only about half of the first line of the White area is shown.
FWIW, I don't normally use the Arlo search bar. I find it much more effective to use Google search with site:community.arlo.com in the search string. Similarly, site:kb.arlo.com if I am looking for a KB article.
There are three scenarios I am seeing:
- If the windows focus is outside the search box, I just see the image I already posted
- If I then press enter at the end of the search string, I get a page of search results.
I already posted (1).
Here's (2):
And here's (3)
The form is trying to show suggested results for us to go to directly without going to the other page. Minor convenience but that seems to be the intended behavior. It is the way that many other search tools work. It is not a necessity but as I said it appears to be something they intend to provide.
Thank you for the tags, I have informed the appropriate team.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
