- English
- Cameras
- Pro 4 Camera. Alerts that motion detected but vid...
All of the videos in my library were gone this morning. New activities were not being recorded. Finally new actives were being recorded but the history is gone.
I have a valid subscription to save recordings.
There has been an update on the backend that should have resolved this issue. There was an issue with notifications being sent for motion detected outside of set activity zones, that is why you were not receiving any recordings in the library. The issue was with the Smart notifications and not missing recordings in the library.
Thank you
Best answers
The issue has been identified and will be resolved shortly. I will provide another update as soon a I have more information to share.
The whole system runs normally until this morning 10:30 (UTC+8). After this time, the cloud have no update on new video while I can find them in my local HDD connected to the Hub and all up-to date video are recorded. Also now the live streaming also failed. It seems the camera runs normally while the network is failed. Anyone knows what's going on and how can I do for this?
P.S. I reset/ restart/ reconnect all the stuff for several times already. I have auto update on the subscription.
Good morning, recordings not showing up in library. Please advise.
This issue occured maybe a month ago, I posted at that time as well, and it resolved itself. This time, my last recording to show up in library was at 6:32 AM EST. No recordings have showed up since, and I have purposely tripped them myself to see what is going on. I get the notification that motion/person detected, but no recording. Yes, my subscription is active and fully paid up.
Firmware status states "no new firmware versions available. Firmware up to date". While trying to access the app, it will sometimes report app is unavailable and then close. Have tried closing app and logging back in; restarting my phone (Android platform) - doesn't fix the issue.
I have tried contacting support about this problem numerous times. There is clearly a software or firmware issue. This all started about 3 weeks ago. I have done every single troubleshooting step there is. I have completely removed, erased and re-added and the problem still persists. My internet connection has not changed, the location of the cameras have not changed. Arlo changed something on their side around 3 weeks ago that broke something. There is no other explanation.
@LoniElaine wrote:
Hello all! I have 2 Arlo pro 3 cameras with a subscription. As of this morning my cameras are detecting motion and I receive notification but when I check the library there are no recordings. Anyone else having this issue?
FWIW, I am not.
I have a 4 camera Pro 3 system with two base stations. No significant issues since I bought them (over a year ago). Alerts are are consistent and real. Happy with the system.
Last night both my wife and I started to get "Motion detected" notifications on multiple cameras. But there are a few things different about these notifications than normal:
- They are triggering over and over and over...every few minutes.
- Our normal motion alerts have the video preview in the notification. These do not.
- Our normal motion alerts have detection (person, vehicle, etc). These do not.
- Here's the kicker...when I go into the Arlo app there are no clips in the library. So despite triggering, it's not recording anything!
Last night I rebooted both hubs...seemed to help a bit but the problem is back this morning. I just went out and rebooted all the cameras but it's happening again. A few other notes:
- "Normal" alerts don't seem to be triggering while these false alerts are coming through. I just walked out to the driveway and nothing.
- Firmware is up to date
- Audio triggers are off
- In the attached you can see the alerts for 2 of the 4 cameras. As an additional data point, those two cameras are each on a different hub. So it's not a specific hub causing the issue.
So why would these cameras suddenly start throwing these phantom notifications with no recordings?!?!? Help!
I am having the same issue. I chatted with support this morning and they were of no help. I believe this is an app or cloud issue, not a local issue.
I keep getting alerts every 10 minutes that there was motion on my camera but when I check there is no recordings in the library.
Hello,
Does anyone have Activity zones enabled at the moment?
yes
I had Activity zones enabled. I disabled them and still got Phantom notifications.
New development.
The Phantom notifications are now starting to show clips in the library but they are REALLY long. Normal clips are 15-30 seconds. The last few clips I've had are 1:03, 1:45, and 4:30!!! Zero motion in any of those clips.
I've been getting phantom push notifications all day today (Android 12 phone). Normally the push notifications come with an animated image preview of the video clip, but these notifications had no image preview, nor were there any corresponding clips in my library. Tapping on the notification caused the Arlo app to crash with a NullPointerException at com.arlo.app.utils.logging.ArloEventLogger.logNotificationEvent(ArloEventLogger.kt:312.
Furthermore, attempting to submit that crash report caused the Android crash reporter (Market Feedback Agent) to itself crash with a java.lang.SecurityException!
Thatsa lotta crashin'
LOL, whatever Arlo is trying to do (in last 5 minutes) is making the situation worse. My cameras have been firing off notifications every 30 seconds and no recordings are in library. No movement at all outside to even trigger cameras, at all.
I'm getting motion alert notifications but no video whatsoever. This just started today. I have tried restarting the app (android platform), and my phone as well. No change. Same issue on my pc. Firmware is up to date. I've tried re-setting my motion settings, re-setting sensitivity (is at 50%) ....everything else I can think of. This is ridiculous.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
