Problem with an Arlo 3 Pro with spot lights camera
  • 5 Replies
  • 1746 Views
ray1425
I have a few Arlo Pro 3 spotlight cameras. After the hurricane blew through one of my cameras stopped working. When I connect the charger the blue light blinks once and then 2 red arrows at the top of the camera blink twice. I have tried holding down the reset button on the camera, nothing happens. I've also tried re-setting the base station, it recognizes the other cameras but not the one I'm having trouble with. Thanks, Ray
5 REPLIES 5
Is there water inside?
ray1425
not sure about water inside, never opened one.
Given the hurricane, I think you should remove the camera from the housing and check.
ray1425
I opened the camera and did find a little bit of water inside.
Hopefully it will work again after it has thoroughly dried.
