Privacy masking
Hello,
Wondering if its possible to mask parts of the camera view, other then the zoom function? The zoom function would work but its only possible to make the Square smaller. That makes it impossible to mask the parts im not allowed to film here in Sweden. Is there another way to do this? Maybe draw lines or more options for this
Deki90,
You may need to physically adjust the cameras field of view. You could apply activity zones to the areas where you want motion detection to take place, but there is no software feature that allows masking or eliminating areas or parts of the field of view.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
receipts
totally frustrated
VMC2030
VMC2030-100EUS
