Not able to set up my essential spotlight camera
  • 5 Replies
  • 1893 Views
ksnevin
Performed all steps to set up cameral but nothing happens. Have viewed troubleshooting steps and no issues
5 REPLIES 5
Can you describe what happens?
For instance, is the QR code being scanned correctly (resulting in a chime sound)?
ksnevin
Yes, heard the chime after scanning the QR code and then after "buffering" I receive a large red X and a message that camera could not be found.
Ok.
  1. double-check that the wifi network security is using wpa2 (AES).
  2. If you can disable 5 ghz in your router, then do before onboarding (turning it back on later).
  3. If the app still fails, try onboarding from a PC browser (my.arlo.com)
Make sure you select the Essential Spotlight when you "add device".  Just selecting "essential" will fail.
Philpug
My original Arlo Doorbell quit working after a year which was the Essential Video Doorbell Wired.
We thought that the wiring may be the issue so we purchased the Wire-Free.
I have not been able to get the doorbell camera to chime when its time for it to read the QR code from my mobile.
I have verified the internet is more than adequate for this system and have no issues with the other 4 cameras I have in and around my home.
Bummed about this.
That means the camera isn't able to scan the code.
You could try printing it from https://qifi.org
Then use the printed version instead of your phone.
