My Arlo essential spotlight camera (VMC2030B) will no longer connect to my internet.
  • 2 Replies
  • 1603 Views
toyotatacoma
After charging my camera, it will no longer connect. It flashes the blue light several times before showing amber. I tried the online advice and removed and reconnected. It will not acknowledge the QR code. the blue light will blink until the battery goes dead. This camera is just under a year old.
It can be a bit fussy - making you shift the QR code around in the field of view.
Have you tried using a PC (my.arlo.com) instead of the phone?  Also, make sure you select the essential spotlight (and not the essential).
Still under warranty, so I suggest contacting support quickly if you can't get it connected.
Bethanie2384
I am having the same issue...flashes quicky, slowly, solid, quick amber repeat and no connection.  I have tried to reset the camera by holding sync until amber light (nothing, never get the light).  Never connects...
