Missing features in app
after the new update on the Arlo app, it is missing the option to arm separately the cameras. I have a door bell camera that I want to have always armed and 2 side cameras that I want to arm at night. The app doesn’t let you do that anymore. It’s really a stupid decision to have remove lid the option.
Actually you can. Modify "Standby" to arm the doorbell. Don't add any other rules to that mode.
Then you can set up a schedule to switches the mode to "Standby" at sunrise and switches it to "Arm Home" at night. You then use "Arm Away" when you are away for a while, and want the cameras armed 24x7. I can give you some screenshots if you need them.
So basically it’s a work around instead of a solution. Manually not being able to switch on every single camera doesn’t feel like an upgrade. It feels like a downgrade. The app doesn’t explain any of this. Unless they make it the app understandable with option of manually choose the action I want for each camera, I’ll just terminate my subscription go with an other brand and throw the whole equipment in the garbage where it belongs.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
