- English
- Cameras
- Is it possible to record video only, without audio...
Is it possible to record video only, without audio?
At work, we have an Arlo Essential Spotlight Camera. We want it to record only video, without audio. I am guessing that this is not an option, since I've been poking around with the settings for a while without finding a way to do it, but before I give up I thought I would ask the community. Thanks.
Nope, as you suspected. Since the cameras have audio built-in, they will record using that audio. I suppose you could try a piece of tape over the mic opening on the camera face but that would likely just muffle the sound.
Turning off the microphone in the camera settings should prevent the camera from capturing audio on live streams and on triggered recordings.
Settings > locations and plans > devices > select your camera > Audio settings > Microphone toggle off
Thanks James, however my settings do not include any Audio Settings or any other option I can find where I can toggle the microphone on/off. That option is exactly the sort of thing I want!
You should see it in the camera settings.
Do you see "Library" on your main app screen? Or do you see "Feed" and "Dashboard"?
StephenB, thanks. My main screen shows me Feed and Dashboard. My Video Settings only allows me to adjust Video Brightness. Nothing else is included in the Video Settings.
The device settings should show both Video and Audio Settings (along with other choices). Can you post a screenshot of what you see on the device settings screen for this camera?
Here are two screen images showing the device settings overall and then the Video Settings tab in particular.
Sorry, I keep hitting "post" before I mean to. Urp.
Audio Settings is supposed to be on that screen (per https://kb.arlo.com/000062422/How-do-I-adjust-the-video-and-audio-settings-on-my-Arlo-device )
I'm tagging the mods ( @JamesC and @ShayneS ) in case they want to follow up.
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
