Image distortion
I recently updated my 3 Arlo wireless cameras (model: VMC3030) and only one of them has a distorted image quality. I’ve tried restarting the camera, and removing and resyncing the camera and it doesn’t change the image quality. It is strange that it is only happening to just one of my cameras. The camera with the image distortion was placed in a shaded porch with no access to water.
We will not be able to see the attached image until a forum moderator has approved it for public access.
If you’re inclined you can make a short 5sec manual recording to the library and then share it by using copy link and paste into your post so it can be viewed.
If the camera is moved closer to the base, does the image return to normal? Try removing/reinserting the batteries when you try this.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
