How do you set auto turn off on a routine?
I can set a start time on a routine but have to manually turn the routine off in the morning or it stays on
How do I set a routine with and end time?
Message 1 of 2
329
The UI lets you set up an scheduled automation that enables/disables another automation. That is limited to enabling/disabling geofencing automations - you cannot enable/disable another schedule automation using that mechanism. I haven't tried that for a while, but when I did test it, I don't think it worked (not 100% sure though). So maybe start by testing it yourself.
Can you give more information on what you want to accomplish?
Message 2 of 2
327
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
