How do I delete multiple images from my doorbell on new Arlo app as you could on other app in librar
  • 5 Replies
  • 3704 Views
Wispa1
Arlo Essential Wired Video Doorbell How do I delete multiple images from my doorbell on new Arlo app as you could on other app in library
Press the three dots in the upper right of the Feed Page, and then select "Manage Events".
5 REPLIES 5
Jokimo
Old android app had ability ti "SELECT ALL" so it wasn't necessary to click each clip to delete ...please bring back this feature... saves a lot of time/button pushing
While there is no "select all", you can select all the clips for a given day with one press.
Jokimo
Bring back the "Select All" function for mass deletion purpose in "Manage feeds".... otherwise deletion requiring check box for each clip can be VERY TIME CONSUMING !!! Annoying and not necessary if you restore the "Select All" feature.
Again, you don't need to select each clip.  You can select an entire day.
I get that is not as convenient as "Select All" if you want to delete everything. But I think most users who routinely delete files are doing that every day or so.
You can also delete everything in the Arlo cloud in the privacy center.  However, that will delete more than the clips if you use the new AI features (recognition and custom detection).
Note I don't work for Arlo.  I'm just pointing out that there are still easy ways to do bulk deletion.
