- English
- Cameras
- Re: Firmware updated notification every login
Hi since the firmware update a couple of days ago I constantly see the notification of firmware updates every time I login to the IOS app.
I have seen that this was a a previously fixed issue but it seems to be back? I have switched off the cameras, uninstalled and reinstalled the app but still appears.
I have the same issue and have had no luck finding information on it. It is quite annoying. The issue came from out of nowhere, and nothing I have done (re-booting all components, etc) has helped.
Are you able to provide a screenshot of the message you're seeing?
this is what I see every time I log into the IOS app. It only lasts a few seconds but it’s there every time I login
Have you tried force closing the app and clearing the app cache?
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
