I have an Essential camera mounted outside. Once I have charged it up (100%), I have noticed excessive draining of the battery life. The camera is not on (live /recording), yet after 7 days, 50% of the battery has been drained and continues to drain. Power management is set at best. Any assistance would be appreciated.
Are you using a solar panel on the camera?
You can also alter the PIR sensitivity in the camera rule for the operating mode.
Thanks for the reply. When I have the camera turned on it will make recordings. However, the camera is disabled and the battery is STILL draining at a high rate.
Thank you. I have tested the camera by moving closer to the router to pick up a stronger Wi-Fi signal and that seems to have fixed the battery draining so quick issue.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
