There's two things here - your WiFi and your base. Since you have a base, it doesn't matter about your WiFi since the base creates its own network for the camera. So, for starters you have the base connected to your router and it's turned on. You should have a blue LED on the base but that depends on which base came with the system so tell us what you see if that's different.
Use the app to claim the base first - use Add New Device on the first screen when you log in and scroll down to Base Station/Hub to start. Once that's successfully added, continue to add the camera(s). Of course, all this is explained in the directions.
@Springman12 wrote:
Ok. Need help. Trying to setup and it said connect to a 2.4MHz connection.
2.4 Ghz - which is one of the WiFi bands.
But ignore that instruction for now, in most cases the setup will work fine when you do.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
