- Currently have an existing Arlo Pro camera paired with base station vmb4000. When the camera is activated by motion, it sends video clips to the base station that I can view in the Library and delete when done with them. How can I set up a new Arlo Essentials wire free doorbell camera to work with the base station the same way? I already have an Arlo Secure account that allows me to access the videos stored in my Library.
Thx
I'm a bit confused here but I think I get it.
You have a subscription so the doorbell can be added with no problem as long as your sub isn't for a single camera (it should show unlimited cameras). The doorbell comes with a 3 month trial but you could cancel that and add it to your existing sub if you choose.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
