Essential camera VMC2030 not staying connected
  • 17 Replies
  • 37368 Views
  • 16 Likes
  • 5 In Conversation
kodpkd
I keep reading all the issues with the essential camera VMC2030 not staying connected, BUT I haven't seen a fix yet.
How do I fix this, get a different system?
kodpkd
SO,,,,, I disconnected the camera, uninstalled it from my app.  Updated the app. Did a full update to the camera then reinstalled it to my system.
So far all works and the camera shows a full signal.
17 REPLIES 17
kodpkd
So after 1 hr. on tech support I did a factory reset on my camera, then reinstalled it from scratch.
Is this going to solve the problem?
kodpkd
kodpkd
SO after 4 days the camera dropped off line again.  There is something really wrong with the essential cameras.
If the camera is brought closer to your hub or router does it do the same thing?
kodpkd
I am testing that now. I switched two of my cameras with the essential closer now.  So far so good.  But when the signal showed 4 bars why would it disconnect?
The WiFi icon shows strength but not possible interference. Sounds like something near the camera that also uses the 2.4GHz band is causing the issue.
kodpkd
I have thought about that. It was on the outside of my garage, nothing near it.
What about neighbor's WiFi? You may want to use a WiFi signal scanner on your phone or laptop to see what shows up at the camera location.
kodpkd
Every neighbor has WIFI........  If this camera is that bad, I will send it back!
Of course.  And that doesn't necessarily mean there is interference.  It depends on how close the neighbor's wifi is to the garage.
I personally don't think the number of bars shown in the app is all that useful.  I suggest measuring the speed of your wifi connection at the garage with your phone.  The Ookla speedtest app (free) is a useful way to do this.  You'd want an upload speed of at 2 megabits or more (Arlo says 1 for the Essential, but I think you need some margin).  Signal quality can vary, so it'd be good to take a couple of measurements in a row, and then do it again at a different time.
kodpkd
SO,,,,,,,, It has been just a few days.  The essential camera is mounted on the side of my house, less than 10 feet from my base.  It just lost connection again. WHY?  Is this a faulty camera?  What should ARLO do about this?
While it certainly could be a faulty camera, what is the house construction? How many walls does the signal pass through and what's on/in the walls in the straight line between the base and camera?
If you have a subscription of any sort use Settings, Support to select the camera and start communicating with official support. They may determine the camera is faulty and replace it if so.
kodpkd
I have been on support hours,,,,, they are terrible.
kodpkd
So, the same camera is still disconnecting.  Now, what I can't figure out, if I leave it disconnected for a few days, it reconnects all by itself.
I can reconnect it if I do a reset or reinstall but I don't get how it connects by itself.
Lee_MSgt
And you’re a “Guru”? Linking a camera either straight in to the computer or through a base unit us a lock. Outside WIFI cannot interfere unless there is a fault/defect with the camera or base. Simple logic demands that. This is why I hate using this forum - no technicians providing a concrete fix
Jo060
Luminary
Luminary
You should update your name to, "keyboard warrior".
However, why not help the person having issue with their camera(s)?
kodpkd
To end this thread.   ARLO sent another Essential camera.   It doesn't have any issues.  It has stayed connected for the weeks now. I have remounted it on my garage with no problems.
Thank you ARLO.
