Since I had a new firmware a couple of days ago my Essential Spotlight Camera connected to the solar panel constantly says it is charging in the app, even in the middle of the night. Currently on 1.090.27.0_8_620e159
Igor. OK, That is not why I bought solar panels.
I am extremely happy with the units. If they could just correct this problem and get the fix to everyone.
Bob
I have reached the same conclusion. I will look elsewhere for another camera.
Before I go anywhere for more then 4 days, I take my Essential cameras down and manually charge them. One time I didn’t, the second day one camera was offline because the battery was drained. Not a pleasant experience.
One of the biggest issues the Essential cameras have is when there is a loss of network connectivity the cameras consistently try to reconnect back to the network and the battery gets used up very fast.  The network connectivity issue can occur for a number of reasons including a power outage.    When this occurs a fully charged camera can discharge in a matter of hours and will require to be taken down and recharged again because a solar panel can't fully charge a camera from 0%.
If this occurs while someone is home you can go climbing for the camera to recharge it again, but if this occurs while no one is home especially for an extended period of time you will not have camera coverage.
Arlo should really fix this as well, along with other issues that these cameras have.
Firmware: 1.090.27.5_38_dbbc23e
Camera is connected to a Solar panel but not charging (red lightening bolt icon). Removed the camera and charged inside house, but the reason I purchased a solar panel was so I would not have to do this. It was working properly for months and apparently stopped working / charging correctly about a month ago. How do I fix this?
My lightening bolt goes from red to green and back now. It is also connected to an ARLO charging solar panel.
It is night time presently but guess what color the display is? It is green. I turn the camera off during the day for at least six hours to let the trickle charge do its thing.
From experience, I also know that the 100% indicator is incorrect.
If someone, one more time, tells me to reset it, I will defriend  that person, PERMANENTLY.
Bob
I see the same update on Android as well. And keeping an eye on it for the last couple of days. Yes it does appear Arlo added an icon for the Solar panel and it shows a green sun icon when the solar panel is charging the camera. Still not sure if the battery info is shown correctly. Out of 3 camera's I see 2 show being charged 100% and they have yet to charge during the day.
I wrote to Arlo through the support function and after some discussion and negotiation they sent me a new solar panel. I've returned the original to them. So far the camera is charging correctly and the red icon is gone.
Two solar panels quit working last night w firmware update and the batteries are draining superfast. One is 600 miles away. I can’t just get there
My solar powered essentials died a couple of nights ago, went from 60% when I went to bed to sending out a low battery email at 1:30am and it was dead in the morning. New firmware too from the looks of it, charged it up to 95% on mains and put it back up again.
Wish they would sort out the firmware and then stop mucking with it,
Agree, I am going to see if they will refund me, i need a reliable system since i am not there.
I have a feeling they may be having financial issues. They have not solved this problem for over a year.
						Arlo Essential Spotlight
2  -
						Bevor Sie kaufen
1  -
						Detección de Movimiento
1  -
						offline
1  -
						receipts
1  -
						totally frustrated
1  -
						VMC2030
2  -
						VMC2030-100EUS
2  -
