- English
- Cameras
- Essential Spotlight Camera thru Base Station vs. S...
I do not want to pay for a monthly subscription. After talking to multiple service techs I was informed that a smart-hub would do away with a subscription and be able to view either on my computer or smartphone recordings for the Essential Spotlight camera. Being retired and on a fixed income, spending another $100 or $150 for a smart-hub is being considered only if it replaces the base station, I can view recordings anywhere and pay NO subscription. My question is the above information true?
Another option is to look for a Pro 2 camera. That is an older model that has 7 day cloud storage included.
Arlo calls the feature you are asking about "direct access to local storage". It needs either a VMB4540 or a VMB5000 base station to work. https://kb.arlo.com/000062337/What-is-Direct-Storage-Access-and-how-do-I-use-it
Caveats here:
- You won't see thumbnails. Instead you will see a list of videos when you access the storage. You select one, download it and view it.
- Local storage is not accessible through the web browser.
- Only the main account can access local storage. Accounts with friend access can not.
- Viewing the video while away from home requires some effort to set up. You'll either need to set up a VPN in your router, or forward ports to the base station in your router.
- There is an issue accessing your local storage on Android phones while away from home, which is currently being investigated.
Note also that there are some other features that require a paid subscription - cloud activity zones and smart notifications.
Caveats here:
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
