The cameras are within the recommended range of 300feet. I have 4 cameras around the house. In two days of owning them 2 different cameras that were both working went offline. It’s not battery related I checked. It’s not location as they both worked at first set up. So far the only option I seem to have is pulling the camera down, selecting the remove device and re syncing. (Why isn’t there just a reset button???). Now when I resend. It just spins looking for camera and never finds it. Yes I’m on 2.4 and yes phone app is on same network. It takes 15 to 20 resynchs of clicking sync button scanning the app pic and praying it finds it. Please tell me there is a better way to get a cam back online. What good is a security camera that goes offline once per day?????
help!
Coolhandluke222,
What does the signal strength icon show for the camera? While the maximum range is 300 feet line of sight, physical obstructions as well as other WiFi signals in the environment will reduce the effective range. How far from your base station/router are the cameras?
I have similar experience for my other 3 cameras they always disconnect and go offline. I have to power on, pair again and resync and its very inconvenient. My other old single camera from Cloud Edge never gave me this kind of experience.
Coolhandluke222, scorpjun
If the signal strength is good and you're still experiencing the same behavior, please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
