Connecting Arlo CCTV to a new Router
  • 1 Reply
  • 1398 Views
ArloMeerket
My Broadband provider is supplying me with a new (improved) router. Can anyone tell me what I would need to do to connect/set up my Arlo VMC2030 to the new WiFi name and Password that will be associated to the new router?
@ArloMeerket wrote:
= Can anyone tell me what I would need to do to connect/set up my Arlo VMC2030 to the new WiFi name and Password that will be associated to the new router?
Personally I make sure the new router is set up to use the same SSID (wifi name) and password that the old router used.
However, if you don't want to do that: Although this is for the video doorbell, I believe it will also work with the VMC2030.  Look for the "connected to" field in the app or web ui.  Obviously you need to do this before the new router is installed.
https://kb.arlo.com/000062357/How-do-I-change-the-WiFi-network-that-my-Arlo-Essential-Video-Doorbell...
You can also reset the camera and add it back to your account.
