- English
- Cameras
- Cannot sync essential spotlight camera with app
Hi, I am so frustrated trying to sync my 3 pack cameras with the app. I’m following all the instructions but it keeps telling me it can’t find my camera. I urgently need your help
You can try the reset procedure:
https://kb.arlo.com/000062880/How-do-I-factory-reset-and-re-sync-my-Arlo-camera-Arlo-Secure-4-0
Make sure your router is using WPA2 (AES) encryption so thew cameras can connect. Also check your router's 2.4GHz settings to make sure there's no special characters in the SSID or password.
Tell us exactly what you've tried and what you see.
@Chrid were you able to get the cameras to sync?
Arlo Essential Spotlight
Bevor Sie kaufen
Detección de Movimiento
offline
receipts
totally frustrated
VMC2030
VMC2030-100EUS
